I'm trying to find a replacement cable for the passenger/right hand side. OEM number is supposed to be 19184307. 1.8L base manual 5 speed, 206K in Vermont. I've got mine off the car and have it hanging trying to get a light weight oil to run down it and free it up. It is much better but I'm not sure I trust it. It hung up the other day and the brake/wheel got really hot. The caliper spring is working fine (the caliper isn't that old, although it is a rebuilt one). It just won't quite pull back to the rest position. I've searched a lot and I'm not sure if the 2.4L would work. The picture looks the same and one GM parts supplier calls for the same 19184305 for both the base 1.8L and base 2.4L. I couldn't find the length though.
The 2009 Matrix looks the same in the drawing but I'm not sure if that would fit either?
Thanks, Tom
