The issue is that the spark plug socket is stuck at the bottom of the spark plug tube. It's binding against the wall of the tube itself. I have tried these options: Magnet is not strong enuf -it just detaches from socket, Needle nose pliers will not reach - to short in length, Vice grips on tube to pull/twist out - will not budge due to binding on socket, Locking extension on socket - not strong enuf to stay locked on socket. I've use WD-40 to soak the sides of the socket but that doesn't seem to make a difference.
I'm stuck now, i've talked to repair places and they indicate that the tube is pressed into the head so there is no way to remove it. I've seen a few tube removal tools on the internet but no video's of someone using one.
At this point i've been quoted $2500.00 to get it fixed, basically a new cylinder head + 15 hours labor to fix what was suppose to be a simple spark plug change. HELP!!!!
Vehicle info: 2009 Vibe 1.8L Base model.
