Hello everyone,
I have a 2007 pontiac vibe and I'm in Saskatchewan.
So we had the vibe for about 2 years, and the original people we bought it from had put in the right axle shaft wrong and the transfer carrier got damaged so we had to get a new transmission because of that.
The original problem we went in with is still there though! What we went in for was the passenger side of the car making a repeated bumping noise and something that sounds like a howling at fairly low speeds (40-60 km/h here in Canada, I think 30-40 mph in US). We are going to go get the tires rotated and balanced in a week from Costco. The problem started when the tires were seasonally changed. So, we took it back to the people who changed the transmission to ensure the axle shaft was in right. I saw it myself, no leak and no excess shaking or anything. They said the noise was the wheel bearing. We got that changed, but the sound was still there. We went back to check with them, and they said the wheel bearings are fine and the axle is fine. This time, though, the howling sound hasn't reappeared, but the bumping noise is still there.
I was wondering what it could be. I know our rotors need to be changed, but I wasn't sure if the rotors could cause such a sound. There is nothing else I can think of that would be causing that sound. It matches the speed of the wheel (speeds up when more speed). When I jack the car up and spin the passenger side wheel, I can hear a grinding sound that's not on the other side.
Just wanted to know if anyone could help me figure out what it is. Thanks!
