Posted in the Off Topic Section FYI
Ontario
ZedTim
Post by ZedTim »
FYI I just saw this and thought I would post it here as well just in case someone hasn't seen it.....I was hoping this would happenAs of July 31st, 2003, the revised TSB (Technical Service Bulletin) addressing the worn cladding on 2003 Vibes with two-tone cladding has been released. This TSB will inspect and replace the appropriate areas of the cladding affected with the new 2004-style cladding (including the newly designed rocker panel).The TSB is # 02-08-111-005A - parts are available for ordering from your dealer as long as they confirm the warranty repair.I've already heard of a few members that have had their new cladding ordered and on its way.
The Vibe is Deceased!!moved on to Bigger
