I have a misfire and my lift has exited the building also. I do have a exhaust leak at my cat or around there, haven't investigated that much. I'm not sure what it could be. I replaced the OCV furthest from the battery and the lift bolts as well as water/oil pumps and timing chain tensioners and sprocket (not the vvtl-i gear however..) The car had been performing remarkably but at last all good things must come to an abrupt end in cars. I also have not cleaned the strainers, I am concerned slightly about the misfiring because I lost lift before due to broken lift bolt but I had been enjoying it for at least about 5k miles now I would say. Any ideas folks?
Also here are what my OBD2 monitors were showing.
https://imgur.com/a/XElYliP
https://imgur.com/a/ILWRZOF
