2006 Base Vibe with 5 speed.
Ordered vehicle new with antilock brakes.
Doing some maintenance which included new axle shaft on Driver's side, new lower ball joint, new struts all corners, new sway bar links.
Was careful not to physically damage wheel speed sensor but currently ABS light and tire pressure light are both on. I know tire pressure system relies on signal from wheel speed sensor. New axle includes the toothed ring for the wheel speed sensor.
I tried tracing wheel speed wire into engine compartment looking for a joint where I could measure ohms and AC voltage when wheel rotates but the wire disappears somewhere under air filter housing.
I have an expensive AUTEL obd2 tool which claims to also do ABS. If I input that my vehicle is a GM product, the AUTEL says it cannot establish communication. If I say I have an Asian or Japanese vehicle the AUTEL system goes a bit further. In 2006 the Matrix did not offer ABS.
The AUTEL works great on engine obd2 issues.
Any suggestions most appreciated
Dave
