2006 AWD Vibe
hansh
2006 AWD Vibe
Post by hansh »
For Sale - 2006 AWD Vibe, auto.
About 185,000 miles.
Sound and sun package
Black, has roof and hatch spoilers
Tires new, summer 2017
Battery new - fall 2017
Front brakes new, approx 1 year ago
New windshield, summer 2017
Remote start
Have new rear brake shoes to go with, rear brakes are still good
Body and interior in excellent condition
Has humming noise from rear end.
Asking $2500.
Email me at jeepcj@wi.rr.com if interested
Can email photos
2005AWD
Re: 2006 AWD Vibe
Post by 2005AWD »
Chances are the "humming" noise from your rear is a bad AWD hub. You can tell if you jack the rear up and spin a tire. One will make the noise, have resistance or possibly both. The resistance you'll feel is the bearings in the hub.
ehoff121
Re: 2006 AWD Vibe
Post by ehoff121 »
Welcome to genvibe!
If it's a speed sensitive humming or growling noise, similar to what you might hear when a manual transmission Honda is travelling in reverse, it's likely a bad bearing in the rear differential.
If you are diy, it's a straightforward replacement, but it's also a lot of wrenching. You don't need to replace the whole differential- just the bearings inside the viscous coupling, which is 4 bolts for the drive shaft and 4 bolts for the cover. Wiggle off the viscous coupling and remove cover & dust shield (watch out for dripping diff oil). Tap off the old bearings, gently tap on the new bearings (front and rear), replace oil seal and dust shield, and reinstall the coupling and drive shaft. Top off differential oil and you should be good to go, as long as you don't break a cover bolt like I did. ;)
There's another 100k miles in this car if it was taken care of.
If you are still thinking of selling, give an indication of where in the world she's garaged... :D
Re: 2006 AWD Vibe
ehoff121 wrote:Welcome to genvibe!
Where in the world she's garaged... :D
We can' help you sell it without knowing where it's located :o
2014 Silverado, 2004 Vibe GT
