Two separate issues, from two separate incidents.
05 base model, 175k miles
First- Recently my side mirrors won't move via the control switch. Neither one. So I'm assuming the switch is faulty. Can anyone provide provide of general steps and what panel(s) need removed to replace this?
Second - several months ago I was removing my phone charger from the cigarette lighter socket. It was kinda stuck so I gave it a tug. As it came out of the socket the charger plug literally fell apart. As this was happening, the left side of the radio / control panel went dark while the right side is still lit up. The radio doesn't respond or work at all, the clock doesn't stay on unless the recall button is pressed, the back lighting on the left side is still out, and the cigarette lighter socket doesn't work. I checked the fuse panel and even replaced the one labeled for the cigarette lighter.
Would replacing the cigarette lighter socket likely fix this issue? Thoughts?
