Hi guys- I have an aftermarket Kenwood stereo I bought from Crutchfield. When I first installed it with the provided wiring harness there was a white noise at every volume except zero. Research brought me to the conclusion that this may have been from the Moon and Tunes amp. To remedy this I swapped to RCA out for the audio as to avoid 'double amping' the audio. It worked! No more white noise and the volume is much more reasonable at lower levels. However, now I'm getting a pop noise in the speakers whenever they receive or lose an audio signal. Further research makes me wonder if this might be a timing issue with the turning on and off of the audio system (amp turns on sooner than the new HU) except that it happens even when the unit is already powered up.
Anyone have any experience with this?
Thank you!
