I have read the power window switch so I will look at replacing that. How would I know if the gas pedal has been updated?tpollauf wrote:Welcome to GenVibe Thomas. As a neighbor just an hour to the north of me alsoWe have two 2009's in our fleet and love them both. One is a manual and the other an automatic. They have the bigger 2.4l engine unlike yours. Radios have knobs that are very delicate and break so that may become a problem. Most of the 09's have already had their gas pedals circumsized due to a Toyota recall. Also the master power window switch may catch fire (supposedly). That's it for recalls. I think there are several TSB's (technical service bulletins) which are one step before a recall, on various different issues. For us 2.4L owners one big one is the bad piston rings which cause engines to consume a bit more than normal oil. You may notice a noisy, shaky steering column. Especially when going over rough terrain. Just learn to live with this for now. One of ours has this condition real bad and the other does not have it at all. Other than that they are great affordable cars. Post pics soon. You already passed the first test .... your location
Thanks for all the info! Is there any way to check if the water pump has been replaced with the upgraded version? I will check on the recalls, hopefully I can find the parts and take care of them myself without having to go to a dealer. Any resources for finding part numbers for upgraded parts for recalls?MacGyver wrote:Welcome to GenVibe! I have a base 2009 as well. This thing is ridiculously reliable, but here are the biggest points of trouble with this car:
1. Radio knobs break and just spin. I replaced my radio with a touchscreen. You can buy 3d printed knobs online if you want to keep the radio.
2. Water pump failure. The original pump is crap, but your car is old enough with enough miles that it should have been replaced already.
3. HVAC controls use wire cables that sometimes break or get jammed.
4. Steering shaft issue. viewtopic.php?t=38057
There is a recall for the clockspring, recall #14139. And a recall #09199 "loss of power brake assist in extreme cold weather" which requires a "modification to the intake manifold and throttle body". Probably a good idea to check on that since you're in MI.
I had the dealer disable automatic relocking of the doors and enabled all doors unlocking on first fob button press. Those things drove me crazy on my previous car, a Matrix.
For fuel economy, I got an UltraGauge to help me drive better. Because you only have a four speed transmission, keep the RPMs below 3K and you should be able to hit an average of 30 MPG easy in the summer, slightly worse in the winter. Ships from TX.
Check if your car had OnStar upgraded to 4G, if it still works you can get a free trial of OnStar including the 4G LTE WiFi. WiFi in a Vibe, who would have thought!
With 136,000 miles, I would be shocked if you were still running on the original water pump.53Bowtie wrote:Thanks for all the info! Is there any way to check if the water pump has been replaced with the upgraded version? I will check on the recalls, hopefully I can find the parts and take care of them myself without having to go to a dealer. Any resources for finding part numbers for upgraded parts for recalls?
I have no record of the water pump ever being changed, what problem did they all have? Leaking? I suppose I will wait for the current one to fail before doing any unneeded work.......MacGyver wrote: With 136,000 miles, I would be shocked if you were still running on the original water pump.
I have the service invoices for my car. Recall 09199 required part no. 19205281, and recall 14139 required part 19205599. Any GM dealer should be able to check in their system if your car had these recalls done, and they should be done free of charge, so no reason to not go to the dealer. Unless you REALLY hate dealerships.
Bearing failure leading to leaking. On mine the pump got extremely noisy. I park in an underground garage and the noise was horrible. I had it replaced before anything started to leak.53Bowtie wrote:I have no record of the water pump ever being changed, what problem did they all have? Leaking?
Great, thanks for the info!MacGyver wrote:Bearing failure leading to leaking. On mine the pump got extremely noisy. I park in an underground garage and the noise was horrible. I had it replaced before anything started to leak.
viewtopic.php?p=513922#p51392253Bowtie wrote:Also, do you have any pics of the touchscreen in dash? Curious to see what it looks like with the trim ring and all. Thanks!
