It finally happened. A headlight bulb burned out.
Now, I am trying to figure out what to replace it with. OEM will just be as good as it was before, which wasn't much. I do a lot of night driving and also there's the DRLs. This makes the higher brands, like the silverstar and silverstar ultra, worthless as they only last a couple months at best, not worth $50. If you even bother looking at the Sylvania packaging, on the back it will say around 150 hours for the silverstars and 1000 hours for the OEM. Xtravision also says 150 hours or so for life.
My friend says get the zxe from Sylvania. No life is listed but I can assume it will be probably around 150-200 or so. Plus, the glass is blue tinted...ech. I can also assume that the bulbs from Philips, Wagner, and others that have higher output probably don't last very long either.
So, I am at a difficult decision.
