Hi all. New member here.
I have a 2006 Vibe, that the fog lights both stopped working. I can't tell you if they stopped working at the same time, but that is my suspicion, due to what I have tried. Here is what I have done/checked so far.
- Both bulbs replaced
- Checked fog light switch. The fog light dash led does turn on, so the switch works.
- Checked the fuse, and it is not blown, but still tried a known working 15a fuse.
- Checked relay by swapping with horn relay, which is the same.
Anything else I can check that could be an issue, and easily accessible. Not sure I'd be able to trace the wires around.
Thanks all.
Todd
