2008 Pontiac Vibe White/Gray
Base model 4 door
FWD/5-speed/1ZZ motor
Fabric interior/Power Mirrors/Manuel windows + Locks
160,xxx and going up
Mobile-1 synthetics
FRAM gold oil filter
GM superior trans fluid
Paint: 6.5 out of 10
Interior: 9.5 out of 10
Mechanical: 9.5 out of 10
Mods: started on 9/14/2016
Engine:
Iridium TT spark plugs
Duralast MAF
TRD oil breather filter matte black/red
TRD oil cap cover anodized red
Thicker style radiator
TCS linkage shifter bushings
Interior:
Sylvania ZEVO super bright (6000k) dome bulbs (cabin + trunk areas)
Black vinyl padded console lid cover
Design Customs dash cover in gray
TRD "don't shift miss" badge
Polk audio badges on front door panels
Grafxwerks white door lock sticker overlay
Grafxwerks white hyper carbon steering wheel emblem overlay
Stereo:
Pioneer AVH280-BT double din bluetooth touchscreen
Polk audio DB652 front door speakers
JBL club series 6520 back door speakers
Infinity Kappa 10.1t 3/4 tweeters in front
JBL Gto tweeters in side pillers
Infinity Kappa 10.5 aluminum tweeters mounted in hatch area
Rockford Fosgate P300-10 300 watt sealed powered subwoofer
Rockville RW81 complete 8 gauge wiring setup with rca cables
Exterior:
Full de-badge on car
Tint World stage 3 tint (30% front, Limo back, added the sunstrip) lifetime warranty
Weather tech window deflectors dark tint (front and back)
DTMOTO OEM replacement head lights onyx black housing
Sylvania ZXE silverstar bulbs
OEM aftermarket replacement fog lights
Sylavania ZXE silverstar bulbs
OEM aftermarket reverse lights
Sylvania ZEVO (6000k) super bright reverse bulbs
Stock tail lights
JDM ASTAR led brake lights
JDM ASTAR led amber turn signal brake light
SMD LED license plate bulbs super white
TRD valve stem covers matte black/red
TRD black carbon shorty antenna
New Yokohama front tires 9/15 (back tires are Yokohama, same tire, with about 75% life left)
Custom work:
Bass knob for subwoofer mounted by driver side
AUX/USB cable running through storage compartment
Hidden on/off a witch so you can watch videos while in motion mounted by driver side
All of the wiring has been soldered
Honeycomb grill has been sprayed matte black using plastidip
Custom install on the tweeters
Plastidip throughout exterior of car
Everything was professionally installed
Everything else on the car is stock
Thanks for looking! Any advice on a suspension/engine/exterior work advice would be awesome! All criticism welcome!!
