Yeah I bought the base bushings, Where do I start?!ImUrOBGYN wrote:You should be able to see the cable underneath. I'm not sure on the 2008, but jacking up the car and removing the front driver side may help. After that, I just started prying. One came out easily, one did not.![]()
Pro tip: Changing the shifter base bushings had a more profound affect for me than the shifter cable bushings. Like them both, however.
I like this but am I blind to where they go?!sideshowalan wrote:This is a great guide on how to remove the shifter. It's the install instructions for the TWM short shifter.
http://www.twmperformance.com/manuals/m ... manual.pdf
