this seems to happen more if the car hasn't ran for several hours, for example first start in the morning...or after i been at work all day and start it to go home. if i am running errands off/on all day it will start normal 90% of the time
here is what it is doing
it will try to turn over for about 1 sec then i hear a spinning type noise...i can try it about 5 or 6 times and it does the same thing...then about the 7th try it start up
at first i thought it was a loose neg ground clamp, the one on the battery, i couldn't get it any tighter and it was loose....so i bought a new clamp but still same thing
any idea help would be great
thanks in advance
2007 vibe
