http://www.ebay.com/itm/2010-Pontiac-Vi ... 1744405020
It makes me reconsider riding my dog in the back seat.vibrologist wrote:Bad rear impact indeed. It is no surprise that the air bags did no t deploy. The impact sensors are in the front and the front is undamaged. Quite possible the driver and front passenger may have walked away from this.
I was thinking the exact same thingColonelPanic wrote:Yow, a Vibe to Sonic Hatchback conversion.![]()
Yeah, especially the Fiat 2 doors..tpollauf wrote:I was thinking the exact same thingColonelPanic wrote:Yow, a Vibe to Sonic Hatchback conversion.![]()
Some of these subcomacts on the road now have very little if any protection in the rear due to the wheels actually extending out so far that they just may end up being the bumper in a rear collision.
The 03s do have an airbag seat weight sensor. I know because my dog does set it off. That's what that the "Passenger" light is on you dash. When it exceeds the weight in the seat with no seatbelt on, it should come on.BenWA wrote:It makes me reconsider riding my dog in the back seat.vibrologist wrote:Bad rear impact indeed. It is no surprise that the air bags did no t deploy. The impact sensors are in the front and the front is undamaged. Quite possible the driver and front passenger may have walked away from this.The airbag would hurt her less. sheesh!
My 03 lacks the airbag seat weight sensor of newer models, or she'd be safe from the airbag since she's only about 55lbs.
In the airbag section, it says is you use a forward facing baby seat in the front passenger seat, adjust the seat all the way back to get it as far from the airbag as possible, but never mentions a weight minimum to set off the airbag.When the key is turned to ON or START, this light will come on as a reminder for the right front passenger to fasten the safety belt. The safety belt light will flash until the right front passenger’s safety belt is buckled. The passenger’s safety belt reminder light will not illuminate if the right front passenger’s belt is already buckled or if a sensor does not detect the weight of a passenger in that seat. If something is placed on the right front passenger’s seat, the sensors in the seat may detect that object and cause the right front passenger’s safety belt reminder light to come on. If this ever happens, move the object to the rear seat or place it in a rear storage area, if at all possible.
When I delivered newspapers in my 09 vibe it was very annoying every time I switched from reverse to drive it would go off againtpollauf wrote:in the 2009-10 Vibes, 60 lbs is the threshold. I remember reading this when I tore the seats apart installing heated seat elements
