Looking for assy to hold hood up..03 vibe
fuzzymaster
Post by fuzzymaster »
All I have is a hole in passenger side fender where this part I believe should be. Thanks
Re: Looking for assy to hold hood up..03 vibe
Looks like these are still available from GM if you wish to go that route.
http://www.gmpartscenter.net/auto-parts ... r=88970748
Not sure what all you need, but there are 3 different parts (16/17/18 in the link above.) There's the grommet in the fender, the prop rod itself, and a clip to secure the prop rod when not in use.
Welcome, by the way!
fuzzymaster
Thanks. I need all three. I guess I will buy from GM unless someone has the parts used. Thanks
Side note, I was able to fix my glove box clicking noise through GV.
