Here's a couple pics of her 11 years ago in her prime. She was a beauty!!
I will guess that is the effect, not the cause. Rods exit blocks when lubrication disappears.BlueCrush wrote:The Vibe is alive again!!! The repair shop said a connecting rod failed sending it through the side of the engine block.
You can also do this if you overfill a Tundra by 8 quarts and start it.jayoldschool wrote:I will guess that is the effect, not the cause. Rods exit blocks when lubrication disappears.
