First and foremost before I get into any details, altho I can't recall names, I've lurked this forum for years finding solutions to a multitude of issues over time and am greatly appreciative.
That said, the issue at hand which I've seen some stuff in the forum that may apply, but I'm not certain. The basic symptom is that the vehicle has declined in its power over the years. But most recently, there is a mountain between our home and place of business and the car will not pass 40MPH with the pedal to the floor when attempting to traverse said route. Further, the engine RPMs are high at that point and basically it sounds like it downshifted for initial power, but never allows an upshift as it gets speed to traverse the steep grade. The car has about 155K miles on it.
It also has an oil "loss" issue that I'm putting a quart in every 700 mi or so. I "think" that is valve stem seals that need replaced. Would that be related?
I know that compression is good (as of a couple months ago when I was testing to diagnose the oil loss). Fuel injectors are good. The best part of all is that there is NO CEL. On the off chance that something had been stored, I still plugged in my OBD II scanner. No DTC codes are found.
Past experience in a different car (94 Saturn) tells me it could be a cat issue. I'd like to be more certain before going down that road because exhaust work is just a nasty job without a lift. Further, it's expensive.
That's everything I can think of at the moment. I'd love some suggestions of further diagnostics I can run (by all means, point me to threads I failed to find). Any help, greatly appreciated.
