Ok, now That I have your attention
 As the topic states, 208K Vibe cranks but doesnt start. I did some basic troubleshooting and found the fuel pump is NOT priming. I turned the key on and listened towards the back of the car and could not hear a whine or hum. I understand you SHOULD hear something for about a second or two and that is the fuel pump priming. I even removed the two bolts and lifted the seat to hear better but I still couldnt hear the fuel pump priming. Sounds like a dead fuel pump right ???....but this is where I got thrown off...I tried cranking the engine and listening for the fuel pump. Obviously the car did not start, however when i turned the key back to the position where I should hear the fuel pump priming...I HEARD the pump. So it seems like the pump isnt priming, but when I crank her up the pump is running ? Now im officially confused. Perhaps this system doesnt need to be primed ? Do i have a bad fuel pump or not ? From my research there are 2 relays associated with the fuel pump. there is one under the hood and one under the instrument panel. I swapped the EFI relay with the FOG relay and under the dash I swapped a relay with a power window relay. No changes. I want to check for fuel pressure, but the fuel rail doesnt have a schrader valve for a gage, so im stuck with just disconnecting a line and having someone crank the engine while I hold the line into a bucket. That wont tell me if its the correct pressure though.
- so is the fuel pump bad ? Not priming, but running AFTER i crank ???? Can someone verify this with their own car ?
- I was going to use some starting fluid to check if its fuel related, but I read that you cannot use starting fluid with fuel injection. Is that true ?
Thankfully I have my sisters car to use for the next 3 weeks, so I dont have to work in a panic but damn....I just spent $38 to fill up !!!
 Any suggestions ? Once I verify that I have fuel or not I can move down the troublshooting tree. Im trying to avoid replacing parts blindly...cause I have done it in my younger days. I think im smarter now
