2009 Vibe passenger door won't open. HELP!
hockeygrl365
Post by hockeygrl365 »
The inside door latch on my 09 Vibe broke, and now I can't open door from the inside or out. I tried to disassemble the door from the inside but can't because it's stuck behind the dash and door seal. Please advise how to get this door unassembled while stuck closed. Thanks!
MacGyver
Re: 2009 Vibe passenger door won't open. HELP!
Post by MacGyver »
Watch the guy in this video, he pushes on the door with his hip and then he's able to open it. Worth a shot.
https://www.youtube.com/watch?v=Cb-xl90ALU4
Can you remove the screw behind the door handle and get enough access that way? It's hidden behind a tiny panel in there.
Can you roll down the window?
I had a similar problem with my old 2000 Impala. It was in the shop for three days while we waited for parts. The door lock mechanism failed because nobody ever used it with a key.
2009 Vibe Base
