My 2003 Vibe does not show all the meters on dashboard except the engine check, door-close and break. Thus, I cannot see my speed, mileage, RPM, fuel...etc (see the attached).
I went to local GMC dealer and they check the cluster but cannot find the problem.They finally unplug the cluster and replug it. It works. But the technics told me that they don't know where is the problem and they don't guarantee how
long it can work (but spend labor and shop supplies $190, see the attached). If it happens again, I should replace the whole cluster and spend ~$600-700 (parts $4xx + labor $190) It stopped work after a few hours I leave the dealer (the same day).
Any suggestion for how to unplug and replug the cluster? (I wamma try if it works again and maybe I can put them together tighter?)
And do you suggest me go back to dealer to replace the parts?
