Yellow cable behind glove box
Fatalmasterpiece
Post by Fatalmasterpiece »
Hello,
While replacing the cabin air filter on my 2004 Vibe I discovered this yellow cable dangling freely behind the glove box. I have no idea what it is for?
I have a 2004 Vibe GT with the Moons and Tunes package but no sub.
ehoff121
Re: Yellow cable behind glove box
Post by ehoff121 »
The only cables I know of under the passenger side dash that are wrapped in ribbed yellow plastic are for the airbag.
Did you recently have the passenger side airbag recall work completed? If so, bring it back to the dealer.
I wouldn't try to reconnect on my own, due to the potential for accidentally triggering the airbag.
Any check engine or airbag lights on?
gtv237
Post by gtv237 »
Definitely an air bag wire. Did you take it in for the recall?
Yep, any yellow wiring, etc in a vehicle is always airbag-related.
Fatalmasterpiece
No I haven't taken it in. I just purchased the car with 121k miles for $4k. After doing some research I really wanted a vibe :)
Hmm... I wonder if the previous owner detached it themselves or took it in for the recall and the mechanics left it detached.
Go to your friendly GM dealer and have them look up if the recall has been done. Let them check for all recalls. My guess is that the PO disconnected the airbag so a passenger would not get killed by it. It's a Takata airbag and you probably heard about the millions of cars being recalled.
ehoff121
Post by ehoff121 »
You may check the status of open recalls for your Vibe online. You'll need the VIN...
https://vinrcl.safercar.gov/vin/
https://my.gm.com/recalls
tommytipover
Post by tommytipover »
You should have an SRS light on as well or somebody's really monkeyed with the system.
tommytipover
2003 base 5spd.
Fatalmasterpiece
I do see the little airbag light is on, so that must mean that it's disengaged right? I'll definitely call about the airbag recall etc.
