Hi everyone, new to the forums. I recently picked up a 2004 vibe base 2wd - and have been doing a lot of maintenance on it since it has almost 200k miles on it.
I replaced the header gasket this weekend - since i could see oil was leaking out the area. Cleaned the throttle body while I was at it as well - and the car is running better and doesn't idle as high as it used to on cold startup. So everything seems to be fine and dandy. However, I noticed that if I blipped the throttle really quickly, I can hear a hissing sound coming from the general header gasket (i think). I don't really know if it was doing this prior to my gasket replacement. Is this normal? I'm assuming it's not but I wanted to check to see before I took it all apart again and looked at the gasket.
I have a video of it here: https://www.youtube.com/watch?v=wDXQRYVuRH4
