New Car battery slightly smaller
Xebaxtien
Post by Xebaxtien »
I bought a new battery for my 07 vibe, its slightly smaller than the original. I was wondering if that could be an issues or not? it shakes abit in the battery rack, If it isn't a problem I thought I would secure it with a piece or rubber or something like that.
thanks
xebaxtien
sideshowalan
Re: New Car battery slightly smaller
Post by sideshowalan »
The battery hold-down should be able to hold it in place, just snug up the bolt.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
ehoff121
Post by ehoff121 »
Series 35 battery is pretty small. What did you replace it with? :?
Xebaxtien
Post by Xebaxtien »
I don't have the specifics on the battery, but I tighted everything down and its not secured. but I went to the garage and they said it was the right battery just slightly smaller so I put some pieces of wood and now it doesn't move anymore
Xebaxtien
Post by Xebaxtien »
samsonite
Post by samsonite »
Break out the tape measure and see how wide you can go. Then stop into the store any measure up the max battery size you can fit. You might need to temporarily remove the battery to get a good look at the clearance. But you should be able to go bigger
