lannvouivre wrote:I can't be entirely sure of how they'd hold up. The 3A-C engines (A family being the predecessor to the ZZ family) use aluminum bearings and have excellent longevity.
http://www.enginebuildermag.com/2012/10 ... -bearings/ Here's an article. It mentions that aluminum bi-metal (aluminum with steel backing) bearings are used most frequently on modern engines and are excellent for low-load engines, which the 1ZZ can probably be safely classified as.
As far as the different sizes go, you have much greater tolerances accepted in an overhaul than what Toyota allows in their factories. You are allowed 0.028-0.080 mm clearance, via service manual. Toyota wants as close to a guarantee as possible that your car will be exactly like the experience they want you to have (basically, perfect), so that's why the sizes vary by 0.007 mm and not 0.25 mm. If you can't fall within the range in the service manual, you will need to have the crank refinished to 0.25 or 0.50 mm undersize and to get the matching bearings, then measure to verify.
Make sure you get everything really clean before you put that puppy back together, and measure the clearance. You may also need new rod bolts for it, I think they are also intended to stretch (stretching has more consistent clamping force) and after stretching, no longer clamp as well.
20160313_143523 by LodeCreative, on FlickrThanks,vibrologist wrote:Oh yes! That sounds like a job well done! Kudos!
vibrologist wrote:I would go for a used engine. Why?
*You would get an engine that was most likely not opened up.
*It is broken in.
*The fix is fast.
Search http://www.car-part.com/ for interchangeable engines in your area.
20160323_171956 by LodeCreative, on Flickr
20150918_114930 by LodeCreative, on Flickr I too did a very similar swap out some 35 years ago. Went from an original 250 Chevy inline 6 to a Plymouth 225 slant six to eventually to a 283 small block Chevy all in a '74 Camaro. A little bit of work but everything fit just fine!noguice wrote:I've swapped slant 6 to small block before (swapping k-member), pulled transmissions and helped my brother cram a quad 4 in his fiero, so I'm not too intimidated, just never know what unique issues you run into on a particular car. Looks pretty straight forward.
20160328_201353 by LodeCreative, on Flickrtpollauf wrote:Yep ... I'd say there's no turning back nowLove that Orange metallic color
2011-06-13_17-33-56_461 by LodeCreative, on Flickr
20160401_225054 by LodeCreative, on Flickr
20160402_150122 by LodeCreative, on Flickr
20160425_120100 by LodeCreative, on Flickr
