My experience for 10+ YEARS WITH THIS CAR. 1st ....the 1st gens need to replace the poor quality hoses under the hood on the EVAP system. They rot out , crack where they are connected and leak..in 3-5 years. ANd you will not get a CEL. Get Gates 5/16" hose and EFI clamps. This solved my 1st bad idle issue after I wasted time changing the intake gasket. Oh joy, now I have orange updated intake gasket as the old black ones do fail. Now when the evap solenoid by driver fender kicks on...click, click like it should. The quality of the idle goes down. I get no codes. Had smoke test done on EVAP and solenoid seals properly. I do get a code 133 once a year like clock work every spring. The O2 sensor replacement did not solve the 133 as the manual says it should. Gas mileage has not changed since the day we bought it new. 22-23 city 30+ hiway for an AWD is good and what the EPA rated it at. Just idles poorly...when evap sol. kicks in. All hoses at intake have much better clamps than OEM. Actually smaller versions of what you see on the radiator hoses. Known as spring clamps. I also check the throttle body used on AWDs for any looseness in the rotation, nothing. The only bad thing that may have something to do with this. For the first few years I would sometimes top off the tank. Meaning pump would click ...stop. But I would add another 1/2 gallon no problem to round it to the next dollar. Could this have damaged the EVAP can charcoal but not give me EVAP codes?
ANd now many years later issues.
Any ideas...any experiences like this bad idle, no codes but associated to the evap ?
