Does anyone know what was being attempted/accomplished by plugging this line (vent line?)? Possibly a way to pass an emissions test?
That's a good oneChiadog wrote: he found a rusty 3/8" ratchet extension plugged into an EVAP. Line at the charcoal canister.
Thanks vibrologist! Interesting video, but probably quite a bit different than the 03 Vibe. The EVAP. systems seem to get more complex with each generation. Amazing that I have never had to look at EVAP in any of my cars! I guess that is the "benefit" of never owning a car newer than my 05 Vibe. I think the plan is to wait a week or so for a code, and if no code - then loosen the gas cap and see if a code is generated. I will update when I hear something.vibrologist wrote:Here is a YT that explains the purge system based on a Mazda 626. Hopefully it helps with your problems.
https://youtu.be/d4vENWOHnEk
It can't be that much different.Interesting video, but probably quite a bit different than the 03 Vibe.
That means the obstructed line is the EVAP line from the tank. It allowed the air (fumes) to escape as the fuel ran into the tank. Normally the fumes should be swallowed by the charcoal canister.he found a rusty 3/8" ratchet extension plugged into an EVAP. Line at the charcoal canister. After removing the obstruction, the gas tank now fills normally!
That means the obstructed line is the EVAP line from the tank. It allowed the air (fumes) to escape as the fuel ran into the tank. Normally the fumes should be swallowed by the charcoal canister.vibrologist wrote:
