Quick tip, the car will idle much better if you reattach ALL the vacuum lines.
Bill
Sure will.wmdiess wrote:Quick tip, the car will idle much better if you reattach ALL the vacuum lines.![]()
That would be the one. Thanks, I feel better about it now.ColonelPanic wrote:Was it the one on the back? Really easy to miss that one.
It will also run for more than a few seconds after startup if you plug the MAF back in.wmdiess wrote:Quick tip, the car will idle much better if you reattach ALL the vacuum lines.
