Lift?
Kirk5691
Lift?
Post by Kirk5691 »
I'm sure this question has been asked before, but it never hurts to ask again. Has anyone found a way to move the lift point? I would like to move the power band lower in the rpm range. Being an old duffer I have in the past advanced or retarded camshafts to fine tune an engine combination or create more top end or low end power. I'm assuming that with the 2zz this is done electronically. Can it be moved around electronically? If so how? Are there aftermarket cams that accomplish this? Or, you can tell me it cost too many $$$ and I should shove a Honda V6 under the hood. Thanks for your help and hilarious comments in advance.
Vibe 2.jpg (46.92 KiB) Viewed 3300 times
You're responsible for your Attitude, Effort, Behavior, & Actions
03 Vibe GT
98 Jeep Cherokee Sport
05 Chevy Suburban
96 Honda VFR 750
98 Yamaha WR400 set up for Hare Scrambles
01 KX125
00 RM250
jayoldschool
Re: Lift?
Post by jayoldschool »
I'm far from an expert, but I do recall reading that you can use the earlier computer and re-pin it. This gives lower RPM activation. Someone with more tech exp than me will know.
treesleavedents
Re: Lift?
Post by treesleavedents »
the 2003 vibe GT has the lowest lift engagement point of any of the models. I think yours is already at the lowest stock engagement point since it's a 2003. The only other way that I've found to change the engagement point would be an aftermarket ECU. Call https://www.ddperformanceresearch.com/ and see what they say.
Kirk5691
Re: Lift?
Post by Kirk5691 »
Thank you for the tips, especially the dd performance info.
03 Vibe GT
05 Chevy Suburban
96 Honda VFR 750
01 KX125
00 RM250
Re: Lift?
If you set it to a low enough point, you will damage your performance. You need an aftermarket computer to change it. I know multiple ones can do it, but usually you're looking to spend at least $1000 on a stand-alone, then probably another $400-800 on dynotuning to make sure you don't go too low.
circuitsmith
Re: Lift?
Post by circuitsmith »
Ideally you'd want lift to engage at the "crossover" point: the speed where output is equal with or without lift.
Toyota probably can't set it that low because of emissions; the greater valve overlap would result in excessive HC at lower RPMs.
2006 Matrix 5-sp
thebarber
Re: Lift?
Post by thebarber »
emu4 from monkey wrench racing with a custom tune
treesleavedents
Re: Lift?
do you mean the ems4?
thebarber
Re: Lift?
Post by thebarber »
treesleavedents wrote:do you mean the ems4?
ya, sorry
