lannvouivre wrote:![Image](http://i.imgur.com/c36gpw8.jpg)
So beautiful! But now obscured by rubber protectors.
Those are the sweetest battery cable I have ever seen! Where to get some?
Thermostat housing. Lay a piece of 180 grit and up on a flat surface and drag the housing flat surface across until you see a uniform scratch surface or throw away the gasket and use Black rtv. If you have one, you can also use a belt sander. Mount it in a vise with the sandpaper side up and holding the housing assembly as flat as possible touch it to the belt until you get a uniform scratch surface. Be careful.
Easiest way to avoid getting shocked is get a helper and have them turn the distributor. Works every time.
Like your project. Nice engine details. Like to see the face of the Mustang owner that gets spanked by a Tercel! You can tell them Tercel means "mouse with heart of lion" in Japanese.
