Part #?
RDUNick
Part #?
Post by RDUNick »
Anyone happen to know what the part number is for the 17mm bolts at the top of the transmission are?
Thanks.
Currently in the garage:
2002 Jeep Grand Cherokee
2003 Pontiac Vibe GT
2010 Audi S4
ImUrOBGYN
Re: Part #?
Post by ImUrOBGYN »
Should be a designation on the bolt itself. Should also be a listing in the Vibe/Matrix manual available elsewhere on this site. And, if you don't know how to i.d. bolts, a good hardware store employee should if you can bring one of them. I might be able to find some time a little later to look it up, but don't count on it as I have company. :|
Hopefully, someone else will know right away and speak up. Good luck.
RDUNick
Re: Part #?
Post by RDUNick »
ImUrOBGYN wrote:Should be a designation on the bolt itself. Should also be a listing in the Vibe/Matrix manual available elsewhere on this site. And, if you don't know how to i.d. bolts, a good hardware store employee should if you can bring one of them. I might be able to find some time a little later to look it up, but don't count on it as I have company. :|
I appreciate the response ImUrOGBYN. I do have one of them handy, the other was MIA when I pulled the transmission.
I have a copy of the '03 manual but didn't see any parts listings or diagrams but I may have been looking in the wrong section.
Don't take yourself away from company on my account. I can run by the parts department or a hardware store.
Cheers!
2010 Audi S4
ImUrOBGYN
Re: Part #?
Post by ImUrOBGYN »
After further thought, I think the manual may only show how to determine bolt and nut strength and torque of our standard bolts, etc. You probably won't find a part number for a bolt. You'll need to determine the grade, length, thread pitch, diameter.
However, since you have a loose bolt, a hardware store rep should be able to help you out. With a bolt in hand, you can determine the grade of the bolt using markings on the bolt head, generally. Bolt diameter and length, obviously, is easy to determine. Now, 'thread count' is generally used in SAE bolts and is determined how many threads/inch. We normally use metric bolts and those are measure using 'thread pitch'. That's best measured using a thread gauge if you have no info on the bolt. I believe you can even print offline a thread gauge, though one made of paper will not be as good as another material, but may still get the trick done if you want to attempt yourself or compare to what a hardware guys tells you. While at the hardware or equivalent store, the new and old bolt can be double checked using a nut that fits both of them as the final test before you leave. Dealerships may have info, too. That probably varies greatly.
This site, https://www.boltdepot.com/Default.aspx, may help you determine it, as well.
I'm still surprised someone doesn't have more direct info. Maybe, everyone is still holidays recovering. Your hardware/bolt store, which most people have one around their town, still may be your best bet if you can't get a direct answer from someone else.
