Automatic Transmission Fluid Question
c2cummin
Post by c2cummin »
I was just wondering if anyone else has noticed if their transmission fluid gets dark quick after changing...
I just did 1 drain and fill last summer(about 20-25,000 km's ago) and noticed today that the fluid is already a brownish colour. Not dark brown, and nowhere near black.
It's still transparent and doesn't smell burnt. The transmission also seems to operate fine, doesn't slip or anything.
Is there a cause for concern about the fluid going brown that quick? The factory filled fluid is what was in it when I changed it and it was getting dark but still more red than anything. I was at around 125, 000 when I changed it.
Any reply would be great!
Thanks!
2007 Base Vibe
bluneon
Re: Automatic Transmission Fluid Question
Post by bluneon »
a lot of the old darker fluid is still in the torque converter won't drain out when doing a drain and fill.
Salsa Guy
Post by Salsa Guy »
^True you only got about 1/3 to 1/2 of the fluid out. I did the same but with a fluid change over.
c2cummin
Post by c2cummin »
Salsa Guy wrote:^True you only got about 1/3 to 1/2 of the fluid out. I did the same but with a fluid change over.
Makes sense. So it's probably just the old 1/2 of the fluid that's getting darker? I just didn't know if there was cause for concern. Like I said there's no noticeable problems.....I plan to do another drain and refill this summer...maybe I'll do it more than once this time...
2007 Base Vibe
Salsa Guy
Post by Salsa Guy »
A fluid change over is very simple. On the my 1st gen the bottom line from the transmission cooler (located in the radiator) is the return line. Disconnect that then connect a 3-4 ft. hose (I used a clear 3/8" tube) and put the other end in a 5 gallon bucket and secure it. The end going back to the transmission plug, I used golf tee. Start the car, add new transmission fluid, the whole time while running the engine, and watch the color of the fluid coming out, it's best to have 2 people doing this. When the fluid starts cleaning up, turn off the car and reconnect the lines. Add 2 more quarts, restart the engine and adjust level. You may find it will need 2-3 quarts to get the level up. All in all it takes about 10-12 quarts to do this. Most dealerships will discount the fluid to $6 a quart if you buy a case. The biggest pain is getting all the plastic crap off to get at the lines.
Doing a drain and refill, every 6 month or so, will work too. It's just a slower process but both never get 100% of the old fluid out.
c2cummin
Post by c2cummin »
Salsa Guy wrote:A fluid change over is very simple. On the my 1st gen the bottom line from the transmission cooler (located in the radiator) is the return line. Disconnect that then connect a 3-4 ft. hose (I used a clear 3/8" tube) and put the other end in a 5 gallon bucket and secure it. The end going back to the transmission plug, I used golf tee. Start the car, add new transmission fluid, the whole time while running the engine, and watch the color of the fluid coming out, it's best to have 2 people doing this. When the fluid starts cleaning up, turn off the car and reconnect the lines. Add 2 more quarts, restart the engine and adjust level. You may find it will need 2-3 quarts to get the level up. All in all it takes about 10-12 quarts to do this. Most dealerships will discount the fluid to $6 a quart if you buy a case. The biggest pain is getting all the plastic crap off to get at the lines.
Thanks,
Maybe I'll try this technique in the summer. I had forgotten that doing just 1 drain and refill doesn't get anywhere near all of the fluid out. I slightly panicked seeing how dark and kinda brownish it was....thought maybe I had some issue I wasn't realizing. Like I said tho it runs and shifts just fine, no slipping either.
2007 Base Vibe
cptnsolo77
Post by cptnsolo77 »
When I do my drain & refill, I do it 3 times ( a week apart ) to exchange all the fluid. Just did it last month. Shifts great at 184K ;)
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
c2cummin
Post by c2cummin »
cptnsolo77 wrote:When I do my drain & refill, I do it 3 times ( a week apart ) to exchange all the fluid. Just did it last month. Shifts great at 184K ;)
Sounds like a good plan as well! How often do you do this?
2007 Base Vibe
cptnsolo77
Every 60K as per the manual 8-)
Burns1210
Post by Burns1210 »
cptnsolo77 wrote:Every 60K as per the manual 8-)
Never - according to the dip stick.
I just did a fluid and filter change for the first time at 245k miles, I don't notice any difference.
2008~Auto~Platinum~Monsoon~Sport Package
