Two weeks ago, I flew to Dallas-Fort Worth from Seattle, WA to check out an 03 Vibe. Sounds nuts, but I have family not far from DFW so I figured if the car was junk, I'd hop on a greyhound and make a trip out of it anyway. Well the car checked out and is in great shape, for a 13 year old car with 143k miles (then). It's already given me over 3,000 trouble free miles.
Well.. aside from a horn issue which I think is now resolved by sandpapering the blade connector on the horn itself. It would work temporarily when the connector was unplugged and plugged back in. It had visible corrosion on the blade. I finally got around to addressing that this morning, but I'll have to actually get out and drive it some first to confirm it's fixed. The wire harness connector may also need treatment.
It has some odd rust on the passenger side strut tower visible from the engine bay, but it seems to be a result of a bad weld from the factory that is exposed to rain running in from the hood, even when parked. (If not especially so). I raised the hood to fix the horn this morning and could see the trail of water leading to the rust so I know that's what's causing it. I will get some Duplicolor Rust Fix and treat the tiny area, then put a towel to keep the leaking in water from getting at it until it dries. Later on I'll get some touch up paint and clear coat for that as well as other places that need it, like rock chips and some missing paint on the front bumper.
Somehow it ended up with 2 different sized tires on each side of the car. Yeah, not front and back.. the sides. 205/55/16 on the passenger side and 215/60/16 on the driver's side. Maybe the larger were on the back when purchased and then got rotated by a shop who didn't know it had different sized tires? Beats me!
I had the transmission serviced (fluid/filter) about 250 miles after I bought it, for routine preventative maintenance since I had no idea if or when it ever had it. The engine oil dropped a little on the dipstick, about 1/10 of an inch over 3,000 miles so I suspect it's a minor leak. It passed emissions testing here just fine.
But yeah, it's in overall great shape and runs and drives like a champ. It has power windows/locks, cruise, CD player.
