Hello all, this is my first post on this site but Ive been an avid reader of post for some time. I am the proud owner of an 08' base vibe this vehicle has been incredibly reliable for a vehicle that is fixing to turn over 200k. Ive been on a crusade to start fixing it up to give it new life for another 200k. For the past two months Ive noticed a metallic grinding noise coming from the pulley side of the engine while running. I was concerned it may be the timing chain so I opened up the oil cap while running to see if the noise was internal. Thankfully I couldn't hear the noise internally but, it defiantly seems to be coming from one of the pulleys. After reading post on this site Ive determined the probable culprit is the Tensioner pulley. I purchased a replacement on amazon along with a new serpentine belt since I will have to take it off I figured I'd replace that while it was off. I am just wanting to check with you Vibe/matrix veterans to make sure I'm not overlooking any potential causes. I saw a post that described the sound perfectly "marbles rolling around in a plastic cup" that is about as close a description as I can get. Any input from any of you fellow owners is appreciated.
JP
