I just got a new to me black '04 base Vibe 5 speed with 140,000km on it and I'm quite pleased. It's a very comfy car and I'm getting just over 30mpg or 7.75 l/100km in 70/30 city/highway driving, which is pretty nice.
I've been searching here and elsewhere for answers regarding the funny clattery sound it makes and I'm having trouble finding posts that match exactly. Mine doesnt make any noise when cold, aside from the rediculous high idle while warming up. But within 10 minutes of driving something starts clattering starting around 2000rmp and getting progressively louder till 3000rmp and above that it stops.. and it only happens on part throttle.. as in just the amount of throttle you would use to hold speed or slightly accelerate. When using enough throttle to pass or give'r a bit there's no clatter at all.. actually sounds really nice..worthy of an aftermarket exhaust and intake I think
Anyhow, I have read about the plastic intake manifolds having a glued flap that comes loose and makes the engine sound like a diesel.. thats pretty much what it sounds like but all those posts seemed to be with the engine idling and didnt seem to have anything to do with engine temperature. Early on I was thinking something to do with oil pressure and its effect upon the lifters so I changed the oil to high quality 10-30 synthetic with about 25% lucas oil stabilizer.. also put some seafoam in the oil for about 200km before I changed it. No change to the noise.
I also have seen all the posts about the oil control valve and its filter.. whos got an opinion on which it is? The intake manifold, oil control valve/filter or ,god I hope not, valve clearances already on an ebgine with only 140,000km ?
Aside from that noise and an absolutely just hard core torqued on clutch adjuster rod nut that I cannot pry loose to save my life, I rather enjoy this car's handing and utility. Especially with the new Continental true contact tires.. really really great tires.
If you read all that, thanks
Jeff
