2009 Pontiac Vibe, 118K miles, mostly short trips on suburban roads. First owner.
Had the passenger side CV fail about 3 years ago. There was no warning sound before it happened. Replaced axle/CV. All appears to be OK on the pass side.
Now hearing strange sounds from drivers side front. Occasionally, I hear a sound like "tock-tock-tock" at the speed of the wheel rotation. You have to be doing at a speed above 20-25 mph. The sound is not a sharp "click". It is more like a washing machine where the load has become unbalanced. But the noise is not ALWAYS there. It seems to be more prominent when the steering wheel is pointed straight head, and disappears when the car is turning.
Also hear the same, or very similar, sound, but more like a rattle, when going over a bumpy road.
Question: Where is this sound most likely originating from? Bearing? Inner/outer CV? Ball joint? Strut? Shock? Wheel?
And can someone provide some simple tests to narrow the problem down?
Thanks!
