I'm just wondering what everyone thinks is the best brand of treatments/additives out there.
Fuel system cleaner, fuel injector cleaner, gas treatment, etc.
I have an '07 Vibe and I've used Lucas and STP. Mainly STP because of the price.
you know you are wasting your money? http://www.bobistheoilguy.com/motor-oil-101/jeff_j1701 wrote:Hello,
+1vibenvy wrote:I add a bottle of Techron to a full tank of gas for each of our Vibes every 5000 miles when I change the oil.
Even that is pretty much a thing of the past. Pure gasoline is oil like and will not mix with water. Ethanol mixes with water. In my area it is getting harder and harder to find ethanol-free gasoline and it is much more expensive the the ethanol blended gas. Therefore I use ethanol blend with about 10% ethanol. That eliminates any moisture problems.Derf wrote:Usually add something labeled to neutralize water collection by ethanol. Agree most fuels now have better additive package, but they go only so far preventing the fuel system collecting moisture.
Agree, before water would collect in the bottom of the fuel tank. Ethanol however, absorbs water causing phase separation in the fuel, you end up with gasoline ethanol blend on top and a water ethanol blend on the bottom. This causes less issues than pure gasoline. Its the concentration of water that could be an issue. Especially in negative temperatures when you drive less allowing phase separation to accumulate.vibrologist wrote: Even that is pretty much a thing of the past. Pure gasoline is oil like and will not mix with water. Ethanol mixes with water
