For some time, I've had oily sludge building up underneath the intake and I figured I would look into it when replacing the gasket... When I took it apart, I was surprised at the amount of sludge that was everywhere. The inside of the intake manifold is coated with it and into the head seems quite a bit crusty. The bolts holding the intake on had fresh oil covering them. I've looked at many pics/videos of this operation and I see *some* oil on theirs but mine seemed a bit excessive.
The gasket was absolutely SHOT. It ripped in two as I was removing it.
(sorta) cleaned up and the proper new orange Toyota gasket installed. Also replaced the throttle body gasket for good measure.
I didn't go too deep with cleaning this thing up, wasn't really sure how to go about it. So I mostly cleaned the mating surfaces and stuck it back on.
I'm trying to figure out why there was such an oil leak with this thing -- was it simply a result of the failed gasket or do I have something else going on? Replaced the PCV valve for the first time earlier this year and noticed a split in the PCV hose. Replaced that with the OEM part from Toyota (since it was a different size on each end, seemed the simplest way to go.) I'll monitor for new buildup over the coming months.
At any rate, the old girl runs beautifully now. Fuel trims looked pretty good on cold start, I'll check them again in the morning. This is the most invasive surgery I've done on a car in quite some time, glad it actually worked.
