Looking for wheel center caps
lawoman301
Post by lawoman301 »
I have searched all the GM parts online sites! Does anyone know where I can find them?
I believe its OEM part #20835338.
Re: Looking for wheel center caps
I bought a used one from these guys:
http://www.centercaps.net/
It was clean, had minor scratches and was a bit dull (wax it). It looks definitely better than a gaping hole.
Ebay should have some, but they will likely be more expensive. I know someone on here has the older style black Pontiac center caps on their 09 model, so that is also a consideration. I find those at the pick a part quite often and have an extra set somewhere.
Derf
Post by Derf »
If you do not have a lead at a local parts yard, would 2nd trying ebay. If the finish is an issue, take the replacement and your Vibe's center caps, wet sand them with 2000 grit or finer then re-clearcoat them. The factory finish seems to dull, as long as the replacement is not gouged, minimal effort will get you a matched set.
