Thanks,
Brian
'05 AWD w/124,500 miles
Maybe in your case the cable got jammed.Mechanic’s answer
Skyvisions , ASE Certified Technician
13,754 Satisfied Customers
Have some one move the shifter inside and under the hood down by the dipstick tube locate the shift cable where it attaches to the front of the transmission. Is it moving the lever on the front of the trans? The cable is known to break right at that pivot. If the arm on the trans is not moving and the cable is then the cable will have to be replaced.
Read more: http://www.justanswer.com/toyota/7t7zz- ... z3l64x7vcX
