Selling my TRD supercharger that was on my Vibe; for Matrixs, Vibes, Corollas, and with further modifications also for 8th gen Corollas and Celicas with the 1ZZ-FE engine.
This is probably the most ideal set-up you could do, because I choose to upgrade the fuel injectors instead of adding the 5th injector, so no need to cut your fuel line and it's easier to tune.
The tune was set-up for a Standard/Manual Transmission vehicle, so if you have a standard it's just a matter of Plug and Play, but if you have an automatic then I would say Tune it afterwards.
This packaged deal includes...
-TRD Supercharger and extra pulley
-Greddy Emanage Ultimate
-Harness to Plug in Greddy Emanage with Stock ECU
-DeatschWerks Fuel Injectors rated at 370 cc
-NGK Spark Plugs # BkR7EIX
-160 degree thermostat
-Dayco Belt #5060850 *in Good-Great condition, no cracks, no uneven wear
-Custom made steel gasket for Supercharger
-Brackets, bolts, and anything else that came with it when I got it I will send out as well. $2200
EXTRAS not included, but can be -AEM UEGO A/F ratio Gauge and wires $110
-Throttle Body Adapter for 05-08 vehicles $100
PM if interested,
Will ship to Canada and Lower 48 US states via UPS.
Paypal only
A tune will be required regardless because every engine has a different amount of wear and what-not.
The ECU of 03-04 Vibes is different from that of 05-08 due to the 05-08 being DBW and not DBC, so you need to swap around I think 4 wires if you are going to a different years bracket than this setup is for.
lannvouivre wrote:A tune will be required regardless because every engine has a different amount of wear and what-not.
If you ran the 5th injector, I don't think you actually need to cut the line. It's plug and play. All you have to do is make a t-splice or two into one of the injectors so that the 5th gets power.
I just remembered that the belt for the Vibe and the Matrix will be different. The Vibe has a different A/C system from the Toyotas, and the belt is a different length (presumably for this reason). Hope that's coherent, one of the foster kittens is obsessed with my monitors and the other is chewing my thumb as I type...
vvtiDavid wrote:Selling my TRD supercharger that was on my Vibe; for Matrixs, Vibes, Corollas, and with further modifications also for 8th gen Corollas and Celicas with the 1ZZ-FE engine.
PM if interested,
Paypal only
-DeatschWerks Fuel Injectors rated at 370 cc -SOLD
AEM UEGO A/F ratio Gauge and wires -SOLD
NEW PRICE- $1800 for the rest of the parts in a bundle
