trb wrote:According to my Chilton's, the purple and pink wires are for the driver's side door speaker. There is a tweeter on some systems that is mounted up high on the window opening in the triangular corner. It is plugged into the same two wires, so that empty plug is for the tweeter harness.
Makes sense. I did notice some models have tweeters on that triangle piece.
I was thinking about buying a Chiltons or Haynes repair manual, but I worried it might be a little too technical for me.
trb wrote:Oh, yes, that is an aftermarket power lock actuator in that pic. It sounds like I was right, that someone had installed an alarm at some point and added locks, but cut it out before you bought it. It might work, but those kind are pretty cheap. I bought 4 for my Mustang and paid like $4 each for them years ago.
That black box is a GPS ignition disabler that a car lot put on the car. I googled that name and several things came up on it. That box with the wire might be part of it too.
http://www.imetrik.com/portal/en/finance/benefits.html
Sounds like you have a bit of a wiring mess there!
I googled it and found quite a bit too, but didn't explore it that much. I emailed them and asked if there was a way for me to safely remove it, or if there was somewhere I could take it to have it removed.
Thankfully all of the wires for it were kept pretty compact, but at the same time, it's really a lot of wiring.
