ColonelPanic wrote:Barring a not-great tuner, one thing to look at is whether you connected the power antenna lead on the harness that plugs into the car. These cars have an antenna amplifier to work around use of the shorter antenna. If your aftermarket radio isn't sending power to the proper pin on the factory harness, reception will be reduced as the amplifier will not be on.
Does this thing have an AM tuner? Usually AM reception is nonexistent if the antenna amplifier is not powered up.
James, thank you so much for your post!
I had purchased and installed an aftermarket radio in my Vibe in March. Although FM reception seemed OK, it was the AM reception that totally sucked. Thinking I had a defective radio, I was about to replace it.
While installing the wiring, I noticed the typical blue/white wire was labeled "System Remote Control" on the radio harness, and the instructions called it a power antenna. Thinking that the power antenna meant those motorized retractable antennas that the Vibe didn't have, I didn't hook up that wire.
Now, after hooking up that wire this morning, AM reception is much better.
BTW, I used the Metra 70-2003 harness, and the blue/white wire connects to the standard non-moons Vibe radio harness terminal B3, a black wire.
Thanks again, James!
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse.(Romans 1:19-20) What do you want most in life?
