They said its leaking between (1) the exhaust manifold and (6) the front pipe. One of the two flanges that holds the bolts and springs that allow the engine to move independently of the exhaust is bent or broken. The only fix according to them is order a new 1,2,4,5,7 and 9, OEM for over $1000 plus labor.
Has anyone else had a similar issue? Would replacing the exhaust with an aftermarket system be cheaper? Thanks in advance.
