2008 need help removing AC fuse?
daisy55555
Post by daisy55555 »
Hello Everyone,
I've been trying to access fuses on my Vibe. Finally found it. Can't believe where it's located and that you can't pull box down to access fuses. Removed black cover but don't have a clue what tool to use in order to pull out fuse. I've tried two different tweezers and it won't budge. Any tips greatly appreciated.
Thanks!
Re: 2008 need help removing AC fuse?
Check the underhood fuse block on the driver's side near the battery. If memory serves me correctly, there's a fuse puller in there. If not, they're readily available at auto parts stores. Makes it much easier to get out of there.
Image Image
gtv237
Post by gtv237 »
You should be able to get it out with some needle nose pliers.
