Front lights
SuPeRioN81
Front lights
Post by SuPeRioN81 »
I'm really don't know anything about cars, but I was driving home last night and all of a sudden my headlights went off... both of them at the same time. My Fogs, parking and high beams still worked though. Is it because my reagular lights burned out or is there something wrong with the wiring? I just found it peculiar, although I put them in at the same time, that they burn out at the exact same time. If anyone can help, I'd appreciate it. Thanks
NSimkins
Global Moderator
Re: Front lights (SuPeRioN81)
Post by NSimkins »
I have a few questions for you..1) Were they the stock/factory bulbs that went out or were they aftermarket?2) Have you done any modifications to the electrical system lately?3) Do you have another bulb to try to swap out to see if the bulbs are really burnt or if it is electrical-related?
SuPeRioN81
Re: Front lights (NSimkins)
1) They are Cool Blues not stock2) I ran some wiring about 2 months ago but they've worked fine since3) I think I still have my stock bulbs lyin around somewhere.It was two in the morning when I found out so I couldn't really test them out
NSimkins
Global Moderator
Post by NSimkins »
quote:It was two in the morning when I found out so I couldn't really test them out Quite understandable. Try installing the factory bulbs (as long as you still have them) and see if you have light. Let us know.
ragingfish
Post by ragingfish »
I have a feeling the headlight fuse does not control fogs or parkign lamps...check the fuses in the engine fuse box...might've blown 'em.
2009 PONTIAC G8
pwarren4
Re: Front lights (ragingfish)
Post by pwarren4 »
Could it possibly be due to using H4's instead of 9003's? Don't H4's pull more current than the stock fuse can handle? Or am I just in La La land here?
P Warren, Columbia, TN, USA Traded my 03 Satellite Monotone Vibe "Slick" for a 05 Satellite Monotone Tacoma Double Cab PreRunner "Freak" in May '08
SuPeRioN81
Re: Front lights
Okay I put in my stock bulbs and they didn't work. Same deal: high beams, fogs and parking lights only...
satur9
Post by satur9 »
check the fuse.and wow first time i noticed theres a pittsburg in california
SuPeRioN81
Re: Front lights (satur9)
Hahaha yeah... Pittsburg no H California... Small ghetto in the bay area lol
