Hello,
Recently, the A/C does not blow cold when the button is pushed. I read Ken's post from July, 2014 on his '03 GT with pretty much the same issue, and sent him a PM to see if that took care of the problem. However, mine does one thing different and that is when I push the A/C/ button, the engine revs down slightly, not up as Ken indicated with his '03. So I was wondering if this indicates a problem different than the A/C clutch/coil? I have a voltmeter so I can test the one wire plug into the compressor.
The A/C button light comes on, fan blows air, but not even close to cold. I assume this is an issue for winter driving as well for when the defrost is on? Not that this matters for the A/C issue, but woth mentioning, the thermostat is likely stuck open as the temp gauge never rises past the second bar from the bottom. Maybe time to kill 2 birds with one stone?
Thanks
