ISO: Splash Guards
xxbradxx
ISO: Splash Guards
Post by xxbradxx »
For my 2006 Base with Rocker Extensions. Really confused which part number i need for the front. Google, eBay and the like are ALL unreliable for this PN. I think is is 12499855 but I cannot find the photo to match this part with what i need.
Here is the set that I need for the front:
Re: ISO: Splash Guards
According to GMPartsDirect.com, the part number is the same as the one you listed. It says SN models which more than likely refers to RPO codes. You can look up RPO codes for your Vibe here. Hope this helps.
From 06pvibe:
For those interested, the GM Accessory part numbers are: 12499855 Front (B57 Trim option,) and; 12498057 Rear... and the rears will fit all Vibes up to 2008. For those with the std rocker panels (non B57) the part number for the front is: 12498056.
Therefore, the one you have pictured is the 12499855 part number for extended rocker panels. Mine also has these.
Another thread:
viewtopic.php?t=8543
Also, assuming you order the splash guards from an online GM site, (I recommend either GMPartsCenter.net or GMPartsDirect.com) they will ask you for your VIN to verify the part/s you're ordering will indeed fit your vehicle.
