I purchased my brothers '03 vibe for my wife to use as her commuter car. My brother is an engineer
who faithfully records mileage, fuel usage, and changes oil every 3000 miles, so I figured this car would be in relatively good condition. It is, but after a couple years, I noticed a noise coming from the front left of the car, and did the 'ol swerve test to verify that it got worse when swerving right. Figured wheel bearing/ball joint/tie rod end or something of that nature. Put Vladimere, (my son names all our cars), up on stands and checked the driver side front tire, sure enough it wiggled just a bit. I proceeded to dissemble the front end, everything, and I mean everything, was harder than I was expecting. It didn't help that Vlad had spent the first 12 years of it's life in the mid-west and the winter snow/salt had taken it's toll. The only thing I was unable to remove was the retaining ring that keeps the bearing from being pressed out. I used penetrating oil, ring pliers, punches, swear words, and everything else I could think of with no luck. Eventually I broke off one of the ends, and the rest was still seized up, so I admitted defeat (not an easy thing for me) and purchased a used steering knuckle. I was smart enough to make sure I got one with the ABS hole, but I missed the AWD vs FWD spec. I have a FWD and the knuckle was for an AWD. I didn't notice the difference until I was re-assembling, and the tie-rod end is designed to attach from the top down on my replacement knuckle, and of course the FWD attaches from the bottom up. Ordered another knuckle. Anyway, my question is, is there a trick to getting that retaining ring out?
